Window layout on Windows is too narrow
When I open the footprint selector it looks like this:
The list on the left is too narrow, and I usually end up expanding it so I can read the category names properly.
Is there a way to make it permanently wider?
There are many informations missing in your question.
  • used kicad version?
  • how do you open the Footprint Library Browser? (from board, from schematic, from xxx)
  • does this narrow first column happen every time on opening the Footprint Library Browser, or only after restarting kicad?
  • for such issues maybe also relevant: windows screen resolution, monitor configuration (single monitor, dual monitor)
FWIW the column-width is saved (and restored) on my system (v7.0.7 and 7.99 on Win10), with some limitations regarding the minimum column width. So in principle the requested function is implemented, it could be a bug in your special case.
Application: KiCad x64 on x64
Version: 7.0.7, release build
wxWidgets 3.2.2
FreeType 2.12.1
HarfBuzz 6.0.0
FontConfig 2.14.1
libcurl/7.88.1-DEV Schannel zlib/1.2.13
Date: Aug 14 2023 02:42:39
wxWidgets: 3.2.2 (wchar_t,wx containers)
Boost: 1.81.0
OCC: 7.7.1
Curl: 7.88.1-DEV
ngspice: 40
KICAD_SPICE=ON
Windows 10. 4k screen with 175% scaling. Single monitor.
I open the Footprint Library Browser by opening a symbol’s properties window and clicking on the library icon next to the footprint text field.
The column width is saved in the Footprint Assignment Tool, just not when I access it as described.
Maybe it’s some combination of the scaling and resolution causing it to reset because Kicad thinks it is too large/small?
Could be. I’m sure I have read similar issues provoked by high-resolution monitors (4k) already on the gitlab bugtracker, but I couldn’t find any this time.
I would recommend to search for yourself on gitlab, and if you find nothing open a new issue. Mention the resolution + windows-scaling. In principle it’s known that wxwidgets (the used GUI-framework) has some problems with 4k-scaling.
good bugreport, but next time please use the standard KiCad / KiCad Source Code / kicad · GitLab section, not the wx-subsection (my mention of “wxwidgets” was only guesswork).
And I would recommend the builtin “Kicad–>Help–>Report bug”-command. This opens the correct gitlab location, prefills the issue with the most needed version information and makes bugreporting easier.
It’s been moved to:
