Width Correction Constrained warning
My DRC passes just fine but when trying to generate a Gerber I get this warning
Warning: Width correction constrained. The width correction value must be in the range of [0.000001 mm; 0.199999 mm] for the current design rules.
I can’t find anything in the design rules about Width Correction
Is it relating to the thickness of the text in relation to the height and width ? as text width and height get smaller so does the thickness, and visa versa.
I’m not sure, I ran it again and it wasn’t there.
That seemed to be the entire warning. But I might of missed if a line under that gave more info.
Just tried to run it a bunch more and still no warning. Thank you for the quick reply.
I’m pretty sure I have seen this warning before and the thickness was corrected manually to be within the constraints, if my recollection is correct that would mean it only happens once if you save the file,
Ahh that might be it. I didn’t change anything but I might of hit save in between without really thinking about it.
