“Value” is a special keyword and we can’t rename it without breaking a lot of things.
This will be easier in 7.0 if we support database libraries / component libraries as a feature.
Then, for example, you can set up all of your resistor parts to hide the Value field and instead show a new field Resistance where you store your 10K
Field names should be unique, so you can’t do that (maybe we didn’t enforce that in old versions of KiCad but we do now)
I think you just have to accept that it’s a quirk of KiCad that “Value” means essentially “Symbol name”, and if you want to store a “value” for a symbol that is something else (like “10k” or “4.7nF”) I recommend putting that in a field called “Resistance” or “Capacitance” etc.
Then I would suggest to make it obvious that it is a KiCad quirk.
Can the text be changed to “Symbol name/Value:”?
Or, “Name/Value” if the text spacing dorks up the size of the fields to the right?
Thanks for the feedback. Now that you have made the comments that this is a KiCad special feature I can sleep better at night!
BTW, a field name of “Value” is not rejected in V5.1.5 that I have on an Ubuntu install.
BTW, a field name of “Value” is rejected in a V5.99 that I have on a Win7 install; however the field name of “value” is not rejected. Is there enough case sensitivity in the program or should this possibly be rejected as well?
As far as I know, KiCad is internally case-sensitive in all the important places. But any external tools that are designed to process KiCad files may not be…
