DIdnt know which category to put this in but I downloaded the digikey kicad library from github, when I try to insert the footprints into Kicad and open my footprints file its empty but when i check the same file outside kicad its filled with footprints. I inserted the corresponding digikey symbols without any problem. Does anyone have a solution?
It might help if you let us know what version of KiCad you are using . . . can you paste your version info here please, you can get it from KiCad > Help > About KiCad > Copy Version Info
Dunno, I haven’t had them installed for a while. But surely you can tell us where you got the current set from so that we can see what the problem might be?
They are the current .kicad_mod format. All you should need to do is register the top directory digikey-footprints.pretty as a library in the footprint library manager as mentioned by RaptorUK. Not the individual footprints, each .kicad_mod file is one footprint.
However note the README.md warning that the repo is unmaintained. I don’t know what issues the author thinks there might be going to v6 (and v7).
Cloned the repo with git clone
Went into Footprint Editor > Preferences > Manage Footprint Libraries
Clicked on + button to add a library
Entered Nickname and Library Path, the latter is a full path, find your download location with the browser
Got a new library called by the nickname, and I can expand it and I’ve shown the first footprint above
