Why is ERC giving warnings for wires that are obviously connected to nets?
Power and Ground come in on J5 Pins 11 and 9, respectively, so I have PWR_FLAGS attached there to tell the system that these are external power and ground nets.
Questions:
  1. Why does U3-5 show "Warning: Unconnected wire endpoint, when it’s clearly connected to net ZYNQ_3.3?
  2. Why does U3-4 show "Warning: Unconnected wire endpoint when J5-1 does not have that warning?
  3. Bonus question: I want to shorten the wire on U3-4, but every time I go to drag the right end of the wire underneath the 'N" of the label, the cursor changes to a wiring tool so I can add to the wire instead of drag the end. What am I missing here?
Thank you!
You haven’t really made the connections to the labels because the small squares are showing. They should disappear when the connection is made.
Ahhhhhh! Thanks! That did the trick!
