Tri-state pins connecting to output pins will report warning, but why is it ?
It is default and reset to default when restart Kicad.
Because you are connecting a tri-state that can potentially be set to output to an output of another device?
But most GPIO is tri-state right ?
So tri-state, bidirectional pins should all generate warnings
Tri-state to tri-state is ok because they can take turns to be output.
Output is ALWAYS output, so cannot go Hi-Z to allow the tri-state to take control
Apart from spotting output-output conflict, the different pin types in ERC check are mostly pretty useless.
I set any IO pins to bidirectional.
They are, all Inputs with no driver should be an error, but once you get into modern multi-function IO chips, defining the rules for each net just gets too complicated and not worth the effort of automating.
A simple feature of banning junctions at crossing wires and detecting wire segments with one end open (the wire not connected to a pin error) would save many trivial schematic errors quickly
