Trackball Debounce SMT January 15 2021a.zip (78.6 KB)
Trackball Debounce SMT October 04 2019a.zip (194.9 KB)
I have attached zips of older and newer versions of a small project. When I open the 2021 (newer) version, I see no pads. The older version looks OK. The two versions are otherwise very similar. But they probably originated from different versions of KiCad.
What is going on?
Edit: The older zip includes some documentation so makes for a bigger zip file. But you can ignore this documentation if you want, or not if you don’t want, or ???
Application: KiCad x64 on x64
Version: 8.0.3, release build
wxWidgets 3.2.4
FreeType 2.12.1
HarfBuzz 8.3.0
FontConfig 2.14.2
Platform: Windows 11 (build 22631), 64-bit edition, 64 bit, Little endian, wxMSW
Date: Jun 3 2024 19:04:47
Boost: 1.83.0
OCC: 7.8.1
Curl: 8.5.0-DEV
ngspice: 42
Compiler: Visual C++ 1939 without C++ ABI
