KiCad has a cache file of the eeschema libraries and embed all footprints inside the pcb board file…
-cache.lib: … a local copy of all the symbols used in the corresponding schematic, so that when the folder containing a KiCad project is copied to a different PC, the schematic can still be opened and printed and will still look the same as the original draughtsperson intended - even if that other PC does not have those symbols in its main libraries (or has symbols that coincidentally have the same name but are completely different).
then the project is portable, unless for 3d models… this can be achieved using the same configuration for the ‘KISYS3DMOD’ or using a relative path to project folder through ‘KIPRJMOD’ environment variable
