what electrical type should I use when battery charger (power out), battery (power in and power out), solar cell (power out) and multiplus inverter (power out and power in) are connected?
Power out pin should be Power Output type.
Power in/out pin presents a problem because it can both provide power and accept power. It depends on the situation. Don’t they usually go to some power controller chip? Do you have any actual schematics?
The type scheme didn’t anticipate this situation where both pins can dynamically reverse roles. If one of the pins is typed as Power Input or Power Output then choose the other role for the other pin. Otherwise make both Passive and accept that the current scheme cannot catch all dubious combinations.
thanks, Passiv is ok for me
