after I have etched the first pcb for SMDs, I have decided to increase the distance between the pads and the copper-fill. I have discovered, that I can change manually the clearance of a single-pad by right-click on it --> edit --> Local Clearance and Settings --> Net Pad Clearance.
After doing a refill, all what happend was that the recangular box around the pad got larger, but the clearance between the pad and the copper-fill remained same. So I am wondering: where do I set the clearance between SMD pads and the copper-fill?
(Well … I wanted to show a picuture here … but the forum says “not allowed for new users”).
