I made a board with 2 solder pads and I exported this board as a .step file.
This board is to be stuck through a base board with a cutout. So I made a footprint with dogbones and al.
Than I want to add the 3d Model of the board I just made. The 3d preview looks fine… But it is simply is no where to be found after the import.
I rotated my camera ofcourse to see if it is somewhere in the var distance. But I can’t find this board anywhere.
I also tried adding the step file to an existing component like a drilling hole (which I do sometimes) but also here. The 3D model of the board, isn’t there
Application: KiCad x64 on x64
Version: 8.0.5, release build
wxWidgets 3.2.5
FreeType 2.13.2
HarfBuzz 9.0.0
FontConfig 2.14.2
libcurl/8.8.0-DEV Schannel zlib/1.3.1
Platform: Windows 11 (build 22631), 64-bit edition, 64 bit, Little endian, wxMSW
OpenGL: Intel, Intel(R) Iris(R) Xe Graphics, 4.6.0 - Build 31.0.101.5333
Date: Sep 7 2024 02:39:48
wxWidgets: 3.2.5 (wchar_t,wx containers)
Boost: 1.85.0
OCC: 7.8.1
Curl: 8.8.0-DEV
ngspice: 42
Compiler: Visual C++ 1939 without C++ ABI
Am I overlooking something?
Kind regards ![]()
Bas
