Where did 3PIN-6mm go?
I’ve been working through the ‘Getting Started’ document, certainly there have been a few changes since it was written but I’ve managed to adapt thus far, some libraries needed adding, some buttons have changed but it’s still useful.
Now I’m at the cvpcb section, which is no-longer a tool from the main menu but I found it and I’m facing issues finding the footprints. LEDV doesn’t seem to be in the default list and 3PIN_6mm isn’t there either. I went hunting for the latter to find it was removed from Divers.pretty a few days ago with a commit message suggesting it went somewhere else … I know not where. Where is it … where’s LEDV?
It might be good if someone went through the getting started guide every 6 months or so to see where things have changed, it is the first point of contact with KiCad for new users such as me and the more slavishly you can follow, the better.
LEDV might have been removed because it was duplicate (similar footprint can be found in LEDs). 3PIN_6mm is Banana_Jack_3Pin in Connect.pretty
Discret.pretty (maybe also Divers.pretty) may disappear in future when the footprints will be sorted or replaced.
Thanks - that’s where it was - I’m still picking my way around KiCad and learning where things are. I now have the example finished and that gives me a base to start.
