Hi all, maybe a silly question , i might have overlooked the option. I would like to draw a drill table.
I see in the pulldownmenu “Place” an “add board characteristic” option and "add board stackup table "option.
But i do not see an “add drill table” where i can see all holes with sizes . Is it under another name ?
I did find a drill table alike function under the pulldown menu “inspect” under board characteristics.
Is there a way to add that automatically ?
You can generate the drill map file and import it as a graphic (e.g., convert PDF to SVG and import into KiCad if you really want it on the PCB layout).
Here is an example, i have drawn the drill table within the green rounded rectangle manually by entering all values manually. Is there not an option in kicad to autogenerate a drilltable ? Saves a lot of time. Especially with complex pcb’s. This is a simple little pcb project. A drilltable is very handy to discover user errors.
As you can see in my example, the drilltable is not even complete. Because the 3 large holes with diameter 3.7mm, i have not mentioned in the drilltable, nor that they should be plated (PTH) or non plated (NPTH).
It would be a great advantage if such an option would be present in the “place” pulldown menu : “add drilltable”.
Drill table is a part of Board Statistics ( Inspect → Show Board Statistics).
It’s exported to a text file. Copy the content and paste it to a text field in PCB Editor on one of the User defined layers.
This is the idea. That the drilltable could be fully automatically generated. See green rounded rectangle.
I have 20 vias with 0.3mm drill hole.
I have 13 PTH holes with 1mm drill hole.
I have 3 NTPH holes with 3.5mm holes.
I have not entered the copper layers for the vias, but it is a two layer board without buried vias.
But such information generated automagically as a drill table is extremely usefull.
Now often i have to specify it for the pcb manufacturer. And i do not have to worry that the PCB manufacturer is gonna asking questions about graphic holes. For the PCB manufacturer this is also a lot more clear to see what i as a customer desire. Easier for the PCB manufacturer and less chances about creating errors in the pcb gerber files and drill files as well.
I have been drawing schematics and PCB files for a total of 30 years , protel, cadence, altium and now i am learning how to use kicad and get what i desire.
