I was trying to build a script to copy default settings for what concern all the clearances, constraints, text and graphics, track widths.
I found that .kicad_pcb should contain a setup section with all the configuration parameters, but my files don’t have it.
Where is this information stored? Is there a way to create a configuration file that someone can run at the beginning to have a predefined configuration setup?
Yes I found the PCB settings in the project file. But looking online I found that PCB settings should have been specified in the PCB file.
Can you send any reference about creating a project template? Thanks
That online-source was maybe written for a older kicad-version. There was a major change from v5 to the newer v6/v7 model.
As I don’t use templates I can’t help with personal experience.
I can only point you to the official manual/documentation: https://docs.kicad.org/
The templates topic got an own section: KiCad | 7.0 | English | Documentation | KiCad
If I look correctly these section covers the usage as well as the creation of templates.
