Where are some functions gone?
Hello all,
I’m running KiCAD 7.0.5 release build. My OS is Linux OpenSuSe 15.3 with the latest updates. Since the update of KiCAD from version 7.0.2 to version 7.0.5 I found some Problems:
On both views, schematic and PCB-editor the sliders are gone. Therefore it is not possible to slide through the schematic or pcb-editor. The only way to do so is the “Zoom-function”, which is really cumbersome.
When I try to route a Signal, the interactive router tool shoves obstacles as expected. But if I insert a via, the via appears only when there is no obstacle. In the past, version 7.0.2, the insertion of a via did also shove obstacles. Here are my router settings.
Does anybody have an idea how to solve that?
Regards
Norbert
The window-scrollbars can be enabled/disabled in preferences–>common–>Show scrollbars (see picture)
Note: these setting is only active after closing + restarting kicad.
mf_ibfeew,
thank you very much. That works fine. Obviously I lost the overview.
Regards
Norbert
