When I place a via, the screen will flash
Hi all,
I met a problem that when I place a via in the PCB editor, the scrren will flash one time, here is a video to show you what it is:
Anyone met the same problem with me?
Application: KiCad PCB Editor (64-bit)
Version: (6.0.9), release build
	wxWidgets 3.2.1
	libcurl/7.83.1-DEV Schannel zlib/1.2.12
Platform: Windows 11 (build 22621), 64-bit edition, 64 bit, Little endian, wxMSW
	Date: Oct 29 2022 23:44:28
	wxWidgets: 3.2.1 (wchar_t,wx containers)
	Boost: 1.79.0
	OCC: 7.6.0
	Curl: 7.83.1-DEV
	ngspice: 37
	Compiler: Visual C++ 1929 without C++ ABI
	KICAD_USE_OCC=ON
	KICAD_SPICE=ON
Sounds like buggy video drivers. Try to update them.
No, this is not a video card issue. I have updated the driver to the latest driver but the issue is the same.
Actually, when I open the PCB editor, in the degining, there is no issue when I place a via until I place a via which is violate rules and then the screen will flash when I place any via ( no matter whether the via violates a rule or not).
Here is a video to show you the issue:
What is your video hardware and driver version? If it’s a laptop does it have dual graphics?
It’s unlikely that the flashing has anything to do with rule violation, more likely to do with vias using shaders to render and your graphics doing something funky.
Well, it’s not a general KiCad issue, your video is the first time I see this issue. So it’s either something weird with your graphics hardware (e. g. a video card issue) or it’s another weirdness with your system. I assume your Windows 11 has no unusual configuration like a special theme or special graphics settings?
Maybe try if this issue also happens with “fallback graphics” in the settings.
I will show you the system information and display information:
System Information
      Time of this report: 12/20/2022, 16:00:45
             Machine name: LAPTOP-2K33VU4L
               Machine Id: {6E44AAAC-903F-4DF7-B2FF-593A93CE9FC4}
         Operating System: Windows 11 ćź¶ćș­äž­æ–‡ç‰ˆ 64-bit (10.0, Build 22621) (22621.ni_release.220506-1250)
                 Language: Chinese (Simplified) (Regional Setting: Chinese (Simplified))
      System Manufacturer: LENOVO
             System Model: 20YM
                     BIOS: GXCN42WW (type: UEFI)
                Processor: AMD Ryzen 7 5800H with Radeon Graphics          (16 CPUs), ~3.2GHz
                   Memory: 16384MB RAM
      Available OS Memory: 15734MB RAM
                Page File: 11730MB used, 7971MB available
              Windows Dir: C:\WINDOWS
          DirectX Version: DirectX 12
      DX Setup Parameters: Not found
         User DPI Setting: 144 DPI (150 percent)
       System DPI Setting: 144 DPI (150 percent)
          DWM DPI Scaling: UnKnown
                 Miracast: Available, with HDCP
Microsoft Graphics Hybrid: Supported
 DirectX Database Version: 1.4.3
           DxDiag Version: 10.00.22621.0001 64bit Unicode
DxDiag Notes
      Display Tab 1: No problems found.
      Display Tab 2: No problems found.
        Sound Tab 1: No problems found.
          Input Tab: No problems found.
DirectX Debug Levels
Direct3D:    0/4 (retail)
DirectDraw:  0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay:  0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow:  0/6 (retail)
Display Devices
           Card name: AMD Radeon(TM) Graphics
        Manufacturer: Advanced Micro Devices, Inc.
           Chip type: AMD Radeon Graphics Processor (0x1638)
            DAC type: Internal DAC(400MHz)
         Device Type: Full Device (POST)
          Device Key: Enum\PCI\VEN_1002&DEV_1638&SUBSYS_380417AA&REV_C5
       Device Status: 0180200A [DN_DRIVER_LOADED|DN_STARTED|DN_DISABLEABLE|DN_NT_ENUMERATOR|DN_NT_DRIVER]
 Device Problem Code: No Problem
 Driver Problem Code: Unknown
      Display Memory: 8363 MB
    Dedicated Memory: 496 MB
       Shared Memory: 7867 MB
        Current Mode: 2560 x 1600 (32 bit) (60Hz)
         HDR Support: Not Supported
    Display Topology: Extend
 Display Color Space: DXGI_COLOR_SPACE_RGB_FULL_G22_NONE_P709
     Color Primaries: Red(0.639648,0.330078), Green(0.299805,0.599609), Blue(0.149414,0.059570), White Point(0.312500,0.329102)
   Display Luminance: Min Luminance = 0.500000, Max Luminance = 270.000000, MaxFullFrameLuminance = 270.000000
        Monitor Name: Generic PnP Monitor
       Monitor Model: unknown
          Monitor Id: LEN8A97
         Native Mode: 2560 x 1600(p) (60.001Hz)
         Output Type: Internal
Monitor Capabilities: HDR Not Supported
Display Pixel Format: DISPLAYCONFIG_PIXELFORMAT_32BPP
      Advanced Color: Not Supported
         Driver Name: C:\WINDOWS\System32\DriverStore\FileRepository\u0373659.inf_amd64_9a59143f68fec526\B373366\aticfx64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\u0373659.inf_amd64_9a59143f68fec526\B373366\aticfx64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\u0373659.inf_amd64_9a59143f68fec526\B373366\aticfx64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\u0373659.inf_amd64_9a59143f68fec526\B373366\amdxc64.dll
 Driver File Version: 30.00.13014.4003 (English)
      Driver Version: 30.0.13014.4003
         DDI Version: 12
      Feature Levels: 12_1,12_0,11_1,11_0,10_1,10_0,9_3,9_2,9_1
        Driver Model: WDDM 3.0
 Hardware Scheduling: DriverSupportState:AlwaysOff Enabled:False
         Displayable: Supported
 Graphics Preemption: DMA
  Compute Preemption: DMA
            Miracast: Not Supported by Graphics driver
      Detachable GPU: No
 Hybrid Graphics GPU: Integrated
      Power P-states: Not Supported
      Virtualization: Paravirtualization
          Block List: DISABLE_HWSCH
  Catalog Attributes: Universal:False Declarative:True
   Driver Attributes: Final Retail
    Driver Date/Size: 2021/11/5 8:00:00, 1837720 bytes
         WHQL Logo'd: Yes
     WHQL Date Stamp: Unknown
   Device Identifier: {D7B71EE2-5578-11CF-B97B-D22A6AC2D335}
           Vendor ID: 0x1002
           Device ID: 0x1638
           SubSys ID: 0x380417AA
         Revision ID: 0x00C5
  Driver Strong Name: oem40.inf:cb0ae414228ff944:ati2mtag_Cezanne:30.0.13014.4003:PCI\VEN_1002&DEV_1638&SUBSYS_380417AA&REV_C5
      Rank Of Driver: 00CF0000
         Video Accel: Unknown
         DXVA2 Modes: DXVA2_ModeMPEG2_VLD  {86695F12-340E-4F04-9FD3-9253DD327460}  DXVA2_ModeH264_VLD_NoFGT  {4245F676-2BBC-4166-A0BB-54E7B849C380}  {6719B6FB-5CAD-4ACB-B00A-F3BFDEC38727}  {9901CCD3-CA12-4B7E-867A-E2223D9255C3}  DXVA2_ModeHEVC_VLD_Main  {EA72396A-67EC-4781-BEDE-56F498F04EF2}  {C152CA8F-738C-461B-AD89-FC292CF8F162}  {514A356C-7027-4AFF-8A60-AFD2C1F672F1}  DXVA2_ModeH264_VLD_Stereo_Progressive_NoFGT  DXVA2_ModeH264_VLD_Stereo_NoFGT  DXVA2_ModeVC1_VLD  {CA15D19A-2B48-43D6-979E-7A6E9C802FF8}  {D1C20509-AE7B-4E72-AE3B-49F88D58992F}  {84AD67F6-4C21-419A-9F0B-24F0578906C1}  {725AD240-786C-471E-AD3C-38F739936517}  {95664FF5-9E03-4C74-BB4F-9178D6035E58}  {5EF7D40D-5B96-49E7-B419-23342094A4CF}  DXVA2_ModeHEVC_VLD_Main10  {65D1FA41-58AF-453A-9CAB-5D981156DA9F}  {2DB154B6-DBB2-4079-A3FF-60D7A898A6AB}  {C74A3FD0-D713-4581-A02E-8EDFB112ACE3}  DXVA2_ModeVP9_VLD_Profile0  DXVA2_ModeVP9_VLD_10bit_Profile2  {603A4756-A864-4F91-BB62-2C935B7A1391}  {C58B9A06-7E89-11E1-BB00-70B34824019B}
      Deinterlace Caps: n/a
        D3D9 Overlay: Not Supported
             DXVA-HD: Not Supported
        DDraw Status: Enabled
          D3D Status: Enabled
          AGP Status: Enabled
       MPO MaxPlanes: 2
            MPO Caps: ROTATION,VERTICAL_FLIP,HORIZONTAL_FLIP,YUV,BILINEAR,STRETCH_YUV,HDR (MPO3)
         MPO Stretch: 16.000X - 0.250X
     MPO Media Hints: rotation, resizing, colorspace Conversion
         MPO Formats: NV12,420_OPAQUE,R16G16B16A16_FLOAT,R10G10B10A2_UNORM,R8G8B8A8_UNORM,B8G8R8A8_UNORM
    PanelFitter Caps: ROTATION,VERTICAL_FLIP,HORIZONTAL_FLIP,YUV,BILINEAR,STRETCH_YUV,HDR (MPO3)
 PanelFitter Stretch: 16.000X - 0.250X
   Component Drivers:
             Driver Name: Unknown
          Driver Version: Unknown
             Driver Date: Unknown
         Driver Provider: Unknown
      Catalog Attributes: N/A
           Card name: NVIDIA GeForce RTX 3060 Laptop GPU
        Manufacturer: NVIDIA
           Chip type: NVIDIA GeForce RTX 3060 Laptop GPU
            DAC type: Integrated RAMDAC
          Device Key: Enum\PCI\VEN_10DE&DEV_2520&SUBSYS_380117AA&REV_A1
      Display Memory: 13876 MB
    Dedicated Memory: 6009 MB
        Current Mode: 1366 x 768 (32 bit) (60Hz)
       Monitor Model: PHL 193V5
          Monitor Id: PHLC0CD
         Native Mode: 1366 x 768(p) (59.790Hz)
         Output Type: Displayport External
         Driver Name: C:\WINDOWS\System32\DriverStore\FileRepository\nvlti.inf_amd64_85d75659658cce14\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nvlti.inf_amd64_85d75659658cce14\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nvlti.inf_amd64_85d75659658cce14\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nvlti.inf_amd64_85d75659658cce14\nvldumdx.dll
 Driver File Version: 31.00.0015.2756 (English)
      Driver Version: 31.0.15.2756
         DDI Version: 12
      Feature Levels: 12_2,12_1,12_0,11_1,11_0,10_1,10_0,9_3,9_2,9_1
        Driver Model: WDDM 3.1
 Hardware Scheduling: DriverSupportState:Stable Enabled:True
         Displayable: Not Supported
 Graphics Preemption: Pixel
  Compute Preemption: Dispatch
      Detachable GPU: No
 Hybrid Graphics GPU: Discrete
          Block List: No Blocks
    Driver Date/Size: 2022/12/5 8:00:00, 772528 bytes
         WHQL Logo'd: Yes
   Device Identifier: {D7B71E3E-6660-11CF-DE7E-0E180EC2D235}
           Vendor ID: 0x10DE
           Device ID: 0x2520
           SubSys ID: 0x380117AA
         Revision ID: 0x00A1
  Driver Strong Name: oem41.inf:0f066de3503f8d0c:Section336:31.0.15.2756:pci\ven_10de&dev_2520&subsys_380117aa
      Rank Of Driver: 00CF0001
         Video Accel:
         DXVA2 Modes: {86695F12-340E-4F04-9FD3-9253DD327460}  DXVA2_ModeMPEG2_VLD  {6F3EC719-3735-42CC-8063-65CC3CB36616}  DXVA2_ModeVC1_D2010  DXVA2_ModeVC1_VLD  {32FCFE3F-DE46-4A49-861B-AC71110649D5}  DXVA2_ModeH264_VLD_Stereo_Progressive_NoFGT  DXVA2_ModeH264_VLD_Stereo_NoFGT  DXVA2_ModeH264_VLD_NoFGT  DXVA2_ModeHEVC_VLD_Main  DXVA2_ModeHEVC_VLD_Main10  {20BB8B0A-97AA-4571-8E99-64E60606C1A6}  {15DF9B21-06C4-47F1-841E-A67C97D7F312}  DXVA2_ModeMPEG4pt2_VLD_Simple  DXVA2_ModeMPEG4pt2_VLD_AdvSimple_NoGMC  {9947EC6F-689B-11DC-A320-0019DBBC4184}  {33FCFE41-DE46-4A49-861B-AC71110649D5}  DXVA2_ModeVP9_VLD_Profile0  DXVA2_ModeVP9_VLD_10bit_Profile2  {DDA19DC7-93B5-49F5-A9B3-2BDA28A2CE6E}  {B8BE4CCB-CF53-46BA-8D59-D6B8A6DA5D2A}  {6AFFD11E-1D96-42B1-A215-93A31F09A53D}  {914C84A3-4078-4FA9-984C-E2F262CB5C9C}  {8A1A1031-29BC-46D0-A007-E9B092CA6767}
   Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                     {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                     {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                     {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                     {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                     {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                     {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                     {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                     {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
             DXVA-HD: Supported
          D3D Status: Enabled
          AGP Status: Enabled
       MPO MaxPlanes: 1
            MPO Caps: Not Supported
         MPO Stretch: Not Supported
     MPO Media Hints: Not Supported
         MPO Formats: Not Supported
    PanelFitter Caps: Not Supported
 PanelFitter Stretch: Not Supported
I try to fall back the nvidia video card settings to default settings in ‘Nvidia control panel’, but everything is the same.
My system information and display information is on above.
Thanks
Yeah so you have 2 graphics cards, one AMD radeon built into the CPU, another dedicated Nvidia 3060 GPU.
Normally your laptop uses the first but switches to more powerful second when it detects the need to. You can try 2 things:
  1. Update your amd drivers, your current one is 1 year old. Nvidia drivers are up to date.
  2. Somewhere in windows settings or nvidia control panel should be a way to force switching to dedicated graphics when kicad is launched. You can try that setting, unfortunately I don’t have more specific instructions as I don’t have a dual graphics laptop with windows on it.
I have updated AMD display card driver to the latest version, but everthing is the same.
And the I force ‘pcbnew.exe’ to use AMD display card/nvidia display card, but everthing is the same.
And I use nvidia control panel to force the settings to default settings, but everything is the same.
Can you try if it happens with Fallback graphic?
You should do it for kicad.exe too.
When I use fallback graphics, and the issue disappeared.
Hi Quick,
When I switch kicad.exe to AMD core video card, the issue disappeared.
I think this is an issue which is related to nvidia video card driver.
Thanks
