What symbol and footprint file formats can Kicad import?
I am trying to import a footprint for a specific C&K switch - L203031MS02Q. It is a DP3T slide switch.
I went to DigiKey to download the symbol, footprint, and 3D model for my project. I was sent to digikey-embedded-partscommunity.com. The is no Kicad option for a download format, but a lot of other formats are available. I have attached 2 screen shots of the formats supported. Which ones will KiCad understand as an import?
I also tried Ultra Librarian which usually had KiCad files, but that site does not have any files for this switch.
I can make my own symbol and footprint, I just was hoping I could find a ready made one.
Thanks!
Showing a screenshot of “all” is not useful. Maybe E-cad or EDA would narrow it down to something sensible.
When opening Preferences / Manage symbol Libraries you get an overview for the currently supported formats:
And similar for the footprints:
The user manual lists the supported filetypes here for symbols and here for footprints.
I included the list in the hope that someone would look at it and say - “Try this …”. The list is alphabetical, and a quick glance shows there are no “E” entries.
When I look at Preferences / Manage symbol Libraries, all I have are legacy and database.
Thanks for the links. It seems that table for the symbol file types is not in the KiCad v7 manual. That is what I searched. Same with footprints. I have not upgraded to version 8 yet.
I compared all the supported symbol and footprint file formats for version 8, and none of them match any entry in the list of possible file formats. I will just make my own symbol and footprint.
Out of that list, DXF (2D) an STEP AP 214 are likely the most useful for a footprint.
@dsa-t Thanks! I will try them.
Ah, yes, that list is probably new in the v8 manual and many of those file types weren’t supported in v7 anyway.
Symbol:
Use “SW_Slide_DPDT”, add two pins and rename to “SW_Slide_DPTT”.
Footprint:
Create one pad with an oval round hole.
Generate and locate the other seven pads with the “Array” tool.
Draw three lots of graphic lines on Courtyard, Fab, & Silk.
Job done. Under five minutes each?
How long to write the post, let alone try to download a footprint which will still need verifying at best; modifying and redrawing at worst?
Oval holes do not seem sensible for that switch. It would need a router with a diameter of less then 1mm. Easy to drill an 1.4mm round hole, but not easy tor milling with a router that’s less then 1mm diameter and a side wards load.
Fair enough comment. My above post has been modified.
Thanks.
I’d have recommended round holes had I actually read the data sheet specs instead of just looking at the drawings. :roll_eyes:
The point of my overall comment was how it is frequently easier and quicker to make/modify symbols and footprints rather than try to download then check another’s work.
Yes, creating footprints in KiCad is usually pretty easy, but it’s hard to nearly impossible to convince people who rather search the internet for half a day then to even start the footprint editor of this.
Unfortunately, DXF (2D) and STEP AP 214 are not recognized by KiCad 7. When I upgrade to v8, I can try them again. Thanks again!
Create a new footprint, then you should be able to import the DXF as graphics
Then just add pads / other graphics you need in KiCad.
And in “Edit footprint properties” you can add the STEP model:
DXF is not a footprint format, it is a mechanical drawing format. The DXF file will be a mechanical outline of the footprint that you can import into the footprint editor as graphics, like dsa-t describes. You would then use it as a reference for creating the footprint yourself (e.g. you will need to add appropriate pads according to the datasheet).
Similarly, STEP is a 3D model format. The STEP you download will be a 3D model of the component that would be useful for checking that the footprint you create is correct, but it is not itself a footprint.
