Hi @maui ,
I found a function '‘Sync 3d mdels ref timestamps with PCB’ in KiCADStepUp but I can’t find any usage instruction or usage example for this function.
So could you give me some explaination on this function about how to use it?
Thanks
Hi @maui ,
Thanks
@xzf16
the idea under this command is the same you have in pcbnew when you sync a sheet with a pcb referring to Reference number instead of time-stamp.
Here a user case:
if you have deleted a 3d model in pcbnew and then you update the board , the new model will have the same reference but a different time-stamp… then to sync its position in FC you will miss the object because of a different timestamp.
The tool allows you to re-sync a 3d model timestamp searching for the reference instead of the timestamp, and updating the ts in FC file
