What is the best way to rename a project?
You should just care about the names of the files KiCad knows about :
  • the .pro file
  • the top level .sch file, it must be named like the .pro
  • make sure that it you rename hierarchical sheet files you also change their symbols in their parent sheet
  • the .kicad_pcb file, it must be named like the .pro
  • your libraries shouldn’t change names if you don’t want to change each component
This might also interest you:
Before comitting anything, it is very useful to add a .gitignore template:
