What have I done? Everything very dull
I must have activated some mode, and now everything is very dim and dull. I went back to another computer running 6, and confirmed that the colors are much brighter.
you pressed " ’ " charachter ?
Not sure.
Pressing that again didn’t change anything.
What does it do?
It’s the shortcut for highlighting net. But it doesn’t work for example with Finnish keyboard.
Euhm, almost, but not really.
@Claudio.Lorini showed a quotation mark, or apostophe, while the highlight is (by default) under the back tick key. (Upper left corner, just under [Esc] on an English / US Keyboard.
But I compared colors and what 3Dogs posted has different colors from the highlighting, so I’m not sure what is going on. I also wonder why the bottom copper layer is not shown. Is it off?
Edit:
High contrast mode (As JeffYoung posted below) also seems unlikely. That dims the ā€œnon selectedā€ layers, but does not change the color of the active copper layer.
Are you in high-contrast mode?
I think is has something to do with ā€œThemes.ā€
It’s not a big problem, I’ll live with it.
There should be a ā€œclassicā€ theme which will give you the old colours. (Though the new ones are better for people that have some level of colour blindness.)
Me? No, it’s just that the backtick ā€œ`ā€ has never worked for me. It’s not an independent one click character in my keyboard, it’s a ā€œdead keyā€. I can reach the shortcut only by switching the keyboard layout. Also some other default shortcuts which require more than one key don’t work, at all (it’s impossible to attach a shortcut to some characters even though they can be typed using AltGr).
that’s correct, i meant the back tick that is the default key (in my ā€˜small’ keyboard is missing so i associated the select net to " ’ ").
Sorry, no, I meant to be asking the original poster if they were in high-contrast mode…
I cycled through ā€˜H,’ and that didn’t fix it.
I’m not sure what the actual problem is in your screenshot. Everything there looks normal, except that you’re using the ā€œclassicā€ color theme rather than the default for 6+. Is this what you mean? The classic theme is more ā€œdullā€.
Now I’m not sure…
It may be some monitor calibration issue.
The colors look very different on my two machines, but it all may come down to the fact that I haven’t calibrated my monitors since changing computers.
I think this can be closed.
Nope, we can see those colors in our web browser to.
I think craftyjon’s last post is on the mark.
If I go to: PCB Editor / Preferences / Preferences / PCB Editor / Colors and set the ā€œThemeā€ to ā€œKiCad Classicā€, then I get the same #840000 red color for the top layer as on your screenshot.
Also: In the ā€œKiCad Classicā€ theme, the bottom layer is green, while in the newer ā€œKiCad Defaultā€ theme, the bottom layer is light blue.
So it looks like your thoughts here were right:
