As I’m working with pcbnew from nightlies, I’ve seen an odd behavior. Normally we were using ‘CTRL + Left Click’ as trace highlight. But right now with nightlies it works like ‘SHIFT + LMB’. Is this on purpose or some kind of bug?
Also couldn’t find a new highlighting method from the menus or obvious shortcuts I’ve tried.
Edit Note:
OK, found the selection method which is left click select and then press ‘u’ (or right click on the selection and then click on the ‘Selection/Expand Selection’ from the context menu.
But still it does not highlight the the whole trace.
Application: Pcbnew
Version: 5.99.0-unknown-2932fe1e6~106~ubuntu20.04.1, release build
wxWidgets 3.0.4
Platform: Linux 5.4.0-54-generic x86_64, 64 bit, Little endian, wxGTK, ubuntu, x11
Date: Nov 22 2020 10:17:08
Boost: 1.71.0
OCC: 7.3.0
Curl: 7.68.0
ngspice: 31
Compiler: GCC 9.3.0 with C++ ABI 1013
KICAD_SCRIPTING=ON
KICAD_SCRIPTING_MODULES=ON
KICAD_SCRIPTING_PYTHON3=ON
KICAD_SCRIPTING_WXPYTHON=ON
KICAD_USE_OCC=ON
KICAD_SPICE=ON
