What does it means "pad net does not match net given by schematic"?
I am getting this warning, and I am not sure what it means:
Can you help me troubleshoot this?
Thanks!
It means that kicad thinks the net assigned to the pads on the PCB is different than the net assigned in the schematic, which would be an error.
Have you forgotten to update the PCB from schematic?
Maybe you can try to assign the net between S1 pad of the USB connector and resistor manually a label?
Why doesn’t the schematic display the ref of the resistor? Is it really R8?
You probably already aware that the DRC is saying that the issue is “Schematic Parity (5)” I just thought I would underline the point and hope your answer is to be found there :smiley:
