What causes this error: Error: Input power pin not driven
I have just drawn my first schematic, I get the error shown in the picture attached, also attached is a picture of the offending circuit. I am using:
Application: KiCad Schematic Editor (64-bit)
Version: (6.0.10), release build
wxWidgets 3.2.1
libcurl/7.86.0-DEV Schannel zlib/1.2.13
Platform: Windows 10 (build 19044), 64-bit edition, 64 bit, Little endian, wxMSW
Date: Dec 19 2022 21:23:04
wxWidgets: 3.2.1 (wchar_t,wx containers)
Boost: 1.80.0
OCC: 7.6.2
Curl: 7.86.0-DEV
ngspice: 38
Compiler: Visual C++ 1929 without C++ ABI
KICAD_USE_OCC=ON
KICAD_SPICE=ON
any ideas where the error codes are explained?
Thanks Steve W
error message 1
I’ll leave jmk and others to answer your FAQ but I just want to say it’s an opportune time to start with 7.0 since it’s just been released and discussions will centre on that going forwards.
Hello and welcome @Steve_W ,
You have labels attached to wires (+9V and GND). You need power symbols.
You will find power symbols in the Kicad libraries in the “power” library.
Yes, very opportune. I, for one, have already forgotten too much of 6. :slightly_frowning_face:
Thank you I suspected as much,
regards
Steve W
Actually you will still get the ERC warnings even after using power symbols. Either ignore them, attach a 9V battery, or attach PWR_FLAGs. That last term is the FAQ search term you should use.
KiCad is just warning you that it doesn’t know where the power for +9V and GND comes from. Once you’re sure that you’re actually supplying power to the components using a battery, DC connector or whatever, you can eliminate the warning by placing a PWR_FLAG symbol on the nets, which acts as a power input for KiCad.
