Warning Symbol pin or wire end off grid
I have just upgraded to version 7.01, after having problems with 7.02. I now get tons of Warning: Symbol pin or wire end off grid. I have been reading that I can ignore this error, but how can I avoid it, and how can I fix a schematic that was created in version 6?
I have tried to build a test schematic from scratch, but if look like differen parts has different grid size, so what would be the best choise, if there is any?
Regards
Ulf H.
This is confusing and not possible to interpret… probably a translation problem.
You can upgrade from 7.0.1 to 7.0.2 or you can downgrade from 7.0.2 to 7.0.1.
Please explain your action and correct your statement. :slightly_smiling_face:
update problems aside (I also didn’t understand the order of your updates) the warning “Symbol pin or wire end off grid” was introduced (from v6–>v7 development) with the following background:
  • for connection between different nets and from nets to symbols the nets/symbol-pins must be on the exact same x/y-coordinate
  • all is well if the user uses a fixed grid (recommended: 0,05")
  • most connection-problems (especially for part-time users or newcomers) arise if a symbol (or individual symbol-pins) is not correctly aligned to that standard-grid - nets are not correctly connected to symbols
  • to help against these (often unintentially) unaligned nets/symbols the ERC-check “nets+symbols are on grid” was developed
  • this test checks:
    • if all nets start/end at a exact grid-position
    • if all symbol-pins are located on a exact grid-position
    • for this check the actual grid-size is used
  • v6 didn’t had this test - so it’s understandable that you get this warnings only with the v7-versions
So if this ERC-check shows many warnings there could be a connectivity problem. So you should:
  • examine the shown error-markers and decide: are the nets deliberately drawn or is there really a problem?
  • for this check the grid should be at the same setting as during net-drawing. If the grid is more coarse than during net-drawing than the nets are obviuosly located offgrid
  • if you often use varying grid-sizes (for instance to draw some nets on dense areas on small grid with very small clearance) - than this ERC-check may not suit your needs and you should turn it off
First of all, thank you for your answer. I am sorry for how i formulated the question, first part was not clear enough.
I first installed 7.02, but there were a lot of warnings when I started using it, and I found that these errors were repored as bugs, and that I could use verion 7.01 istead.
I would have reinstalled latest verion of 6 and waited for the bugfix, but alas my libraries was upgraded and I did not want to install all the parts I had downloaded once more.
When I start a project I have to decide what grid is the most favorable (I am not a very experinced user!) so do you have any sugestions about what would be a reasonable choise?
Best regards
Ulf
Use 0,05".
The standard kicad-libraries also use these 0,05" grid for all symbols. So this is the grid-value with the fewest problems.
advice:
  • change grid only for documentation purposes (value/reference-string, graphics / describing text-elements or so)
  • always switch back to 0,05" after using a finer grid
  • if you want to place these graphics/text try if you like the workflow with the “CTRL”-key as modifier: this switches off the grid-snapping for the current move-action. So grid-change could be completely avoided
  • if you already have some nets/symbols placed offgrid: select them (or select all on the schematic) → RMB-click–>context-menu–>align elements to grid
Thank you SO much! I’ll keep that in mind :grinning:
Was there a fix for this? My schematic has 999+ warnings for this. That’s a lot of connections to redo.
I got rid of most of those by pressing alt-2 which set my second grid size. 0.6350mm
