Warning message: schematics contains symbols that have leading and/or tralling white space field names
Hi :slight_smile: New to the forum
When opening one of my schematic I get the warning message on top of the screen:
Schematics contains symbols that have leading and/or trailing white space field names
Have run Electrics Rules Checker but it does not come up with this warning.
How can I locate the symbols which have the white space fields??
Otherewise just so very pleased with KiCad … what a great toolbox :smile:
I don’t know, but note that it’s the field name that has stray white space, not the contents of the field. Did you add any fields? Are some of the symbols from non-KiCad libraries?
Edit: maybe if you export a BOM you can see all the fields names and values.
Ok I found one …
I have made fields for JLCPCB … and found one with a trailing white space!!
… but, damn it, there are so many components to go through manually to fix …
On the other hand it did not seem to affect my upload to JLCPCB … so must be the MFR.Part # field I made …
Use the Edit Symbol Fields dialog (the same as the BOM dialog). You can rename the field there for all symbols. But this doesn’t work for libraries, only schematics.
A tool I wasn’t aware of … thanks … could see I had multiple field names which should have been the same so was fairly easy to locate the 3 components that was in question … Thanks for the help all :slight_smile:
