According to Ti the INA2180 is an 8 pin VSSOP (*0.65 pitch, 3mm^2). However in Kicad the VSSOP is 0.5 pitch and a different dimension. The one that appears to fit is:
Housings_SSOP:TSSOP-8_3x3mm_Pitch0.65mm
https://www.ti.com/general/docs/lit/getliterature.tsp?baseLiteratureNumber=sbos741&fileType=pdf
How to verify this is correct?
Andrew
By checking all dimensions of the footprint against the datasheet values.
I found freecad + kicad-stepup + drawing dimensions is a good tool for this task.
(The newest version of stepup is only available via the freecad 0.17 addon manager)
This allows you to create similar drawings then i did in this pull request comment: Adding newly scripted molex connector footprints (The rest of them) by poeschlr · Pull Request #60 · KiCad/kicad-footprints · GitHub
Here a sketch of the footprint compared to the maximum pin dimensions: (I know i should have used some sort of statistical calculations to get the “true” toe, heel and side measurements.)
@snoopy20 manufacturers love having very slight variances between footprints and naming them different things.
For this reason, aside from the “generic” footprints like the one you linked above, we have provision for manufacturer specific ones.
Here’s an example of a Texas Instruments footprint from that library - https://github.com/KiCad/kicad-footprints/blob/master/Package_SSOP.pretty/Texas_R-PDSO-N5.kicad_mod
The S-PDSO-G8 footprint doesn’t currently exist in the KiCad libraries but you can contribute it very easily
Then other users can make use of it also!
