Viewing footprints
As I prepare to put a project into stasis, I find I have a pile of various footprints that I don’t quite recall what they are.
How can I load them into KiCAD just to see what they are so I can keep only those that I used? I don’t see a File / Open Footprint command in the footprint tool.
Where are these footprints?
Surrounding the board?
In a project library?
In some folder in your OS?
Scattered around on the floor beneath your desk (sorry, couldn’t help myself) ? :grin:
A footprint library is a set of text files. Can you not look at them for clues from the fields?
For example here’s one from my library:
(module DIPS3048W51P254L2400H1075Q10N (layer F.Cu) (tedit 5E281AF2)
(descr SM411006N/15)
(tags Display)
(fp_text reference DS** (at 0 0) (layer F.SilkS)
(effects (font (size 1.27 1.27) (thickness 0.254)))
(fp_text value DIPS3048W51P254L2400H1075Q10N (at 0 0) (layer F.SilkS) hide
(fp_line (start -1.885 -7.045) (end -1.885 0) (layer F.SilkS) (width 0.2))
(fp_line (start 32.365 -7.045) (end -1.885 -7.045) (layer F.SilkS) (width 0.2))
(fp_line (start -1.885 17.205) (end 32.365 17.205) (layer F.SilkS) (width 0.2))
(fp_line (start -1.885 -5.775) (end -0.615 -7.045) (layer F.Fab) (width 0.1))
(fp_line (start -1.885 17.205) (end -1.885 -7.045) (layer F.Fab) (width 0.1))
(fp_line (start 32.365 17.205) (end -1.885 17.205) (layer F.Fab) (width 0.1))
(fp_line (start 32.365 -7.045) (end 32.365 17.205) (layer F.Fab) (width 0.1))
(fp_line (start -1.885 -7.045) (end 32.365 -7.045) (layer F.Fab) (width 0.1))
(fp_line (start -2.135 17.455) (end -2.135 -7.295) (layer F.CrtYd) (width 0.05))
(fp_line (start 32.615 17.455) (end -2.135 17.455) (layer F.CrtYd) (width 0.05))
(fp_line (start 32.615 -7.295) (end 32.615 17.455) (layer F.CrtYd) (width 0.05))
(fp_line (start -2.135 -7.295) (end 32.615 -7.295) (layer F.CrtYd) (width 0.05))
(fp_text user %R (at 0 0) (layer F.Fab)
(pad 10 thru_hole circle (at 30.48 0) (size 1.1 1.1) (drill 0.7) (layers *.Cu *.Mask))
(pad 9 thru_hole circle (at 30.48 2.54) (size 1.1 1.1) (drill 0.7) (layers *.Cu *.Mask))
(pad 8 thru_hole circle (at 30.48 5.08) (size 1.1 1.1) (drill 0.7) (layers *.Cu *.Mask))
(pad 7 thru_hole circle (at 30.48 7.62) (size 1.1 1.1) (drill 0.7) (layers *.Cu *.Mask))
(pad 6 thru_hole circle (at 30.48 10.16) (size 1.1 1.1) (drill 0.7) (layers *.Cu *.Mask))
(pad 5 thru_hole circle (at 0 10.16) (size 1.1 1.1) (drill 0.7) (layers *.Cu *.Mask))
(pad 4 thru_hole circle (at 0 7.62) (size 1.1 1.1) (drill 0.7) (layers *.Cu *.Mask))
(pad 3 thru_hole circle (at 0 5.08) (size 1.1 1.1) (drill 0.7) (layers *.Cu *.Mask))
(pad 2 thru_hole circle (at 0 2.54) (size 1.1 1.1) (drill 0.7) (layers *.Cu *.Mask))
(pad 1 thru_hole rect (at 0 0) (size 1.1 1.1) (drill 0.7) (layers *.Cu *.Mask))
(model ${KICAD_USER_3DMOD}/sm411006n.wrl
(at (xyz 0 0 0))
(scale (xyz 1 1 1))
(rotate (xyz 0 0 0))
It is actually an inch-high LED display.
@jmk asked the right question here.
Going further, assuming you have a bunch of files spare files… then you can put all of them in a folder. and rename it to my_amazing_footprint_lib.pretty. The important part is the .pretty in the end.
Then create a file called fp-lib-table of just go inside a Kicad project folder that already has this file. Then edit it adding the path of this .pretty folder like:
(fp_lib_table
   (lib (name "MY_AMAZING_LIB")(type Kicad)(uri PATH_TO_THE_LIB/my_amazing_footprint_lib.pretty)(options "")(descr "My Amazing Lib"))
Then, launch Kicad, go to the Footprint library, and check if you can find this MY_AMAZING_LIB library full of footprints.
Some tweaks here and there would be needed on this tutorial because you may have other issues. But the process is something like that.
Silly joke:
Post office employee: I’m sorry about the damage to your parcel, it’s because it wasn’t properly stamped.
Irate customer: What, you used the wrong foot?
:rofl:
…wisenheimer.
Best done with “waffle stomper” boots after stepping into something…
Separate out the files into respective directories: lib, dcm and bck files are for symbols, and kicad_mod files are footprints.
