I’ve used eagle in the past and it contains a tool using which I can choose a part in the schematic and the corresponding part gets highlighted in the board design.
Is there a way I can select a component in Eeschema and see the corresponding component in pcbnew?
Are you talking about clicking on a symbol in EEschema that the footprint is marked in PCBnew and vise versa?
That works when you start EEschema/PCBnew from within KiCAD main window and work on a project.
If you start EEschema/PCBnew standalone they don’t have those hooks running. The marker is a modestly visible white cross in either application.
IMHO it could be a bit more prominent, but one get’s used to it and I’m sure if any dev wants it to highlight the whole symbol/footprint it will happen
By the way, this feature is called “cross-probing” in the industry
For me it also works if I start Eeschema and Pcbnew separately (not from KiCAD main window). Perhaps it’s because the project file, top-level schematic file and layout file all have the same name and reside in the same directory.
Hm… I forgot about that. Thx fro the reminder… so I wait until EEschema runs on GAL too, then I’ll switch (as I still miss the less obvious grid/dot from Default - darkest grey is still to prominent - and the additive color mixing for the layers, i.e. green+red=yellow)
I’m not involved in KiCad SW development so I have no clue about 4.1.0 release timescale.
Besides I always run nightly builds so I don’t really care about stable releases.
Well, I agree, one is less likely to run into bugs on a stable release of KiCad. I’ve been using KiCad nighties quite actively during last year and rarely experienced a crash (but other people’s experience might differ). And indeed sometimes new features are too tempting (e.g. rounded rectangles).
Hehehehe, me too - unless I’m in the middle of something that needs to be worked on - then I stick to what I have installed as I got bitten by the “never change a running system” bug a bit too often
