using the git version of Kicad, for some reason the via pads are missing if I print using the print dialog, while on the plotted images they are present as expected. What is the reason for this, am I missing some setting, or is it a bug?
Probably a bug. Report it in the bug tracker https://gitlab.com/kicad/code/kicad/issues. Remember to copy and paste the version information from Help->About->Copy Version Info (saying “git version” or “the latest” isn’t enough).
It was set to “Small mark”, but the pads won’t be printed regardless of how I set this option.
Drill mark is the spot in the middle of the via where the mask should be actually missing, so the “Drill mark” option should not affect whether the pad itself is printed or not.
I’m not sure if it makes sense to not print the pads and there doesn’t seem to be any option to control that.
Then it could be a bug.
Anyway I only use the print function when I want to see more than one layer on the same file.
For printing I always use plot, sometimes to pdf and mostly to gerber.
I can confirm this bug ( 5.99.0-807 still there). Did you report the bug ? I can’t find it in issues list…
My problem is, that I need a pdf printed in A5 size. I can select printing size in the print dialog, but not in
the plot settings. So. I can’t use print due to this bug and can’t use plot due to missing pdf settings
