I have a strange problem. Some vias in an area are UNselectable.
PCB is 4 layers. There are a TO-252 and a TO-220 at the bottom of the pic. I’ll likely use the TO252 but will add holes for the TO-220 in case I need a heat sink.
Under the common tab area, I manually added an array of Vias (weeks ago. I move at a snails pace). Today I decided to remove 2 of the vias and find I am unable to Select one or more of the vias in the staggered array. Yet, I am able to select and remove adjacent vias from the line of vias above the array.
I’ve tried: individual select, drag right, drag left, Lock/unlock, closed and restarted Kicad V6. No joy.
I tend to save the file ofter but leave KiCad open for days at a time. Recently I got a warning about saving things out of sync. Never saw that before and not sure exactly what it meant. Everything has been working fine for weeks/months.
I know this is a wierdo, but so am I…
