I’ve tinkered about as much with it as my motivation allowed me for today.
- I cleaned up the schematic a bit (no overlapping texts). Drag a box a round things to move, and then press Tab to enable the rubber band drag mode.
- With: **Update PCB form schemtic, I kept the “single pad nets”, as creating and deleted those adds crud to the info window.
- Moved the resistors and capacitors around a bit. I did not move any of the connectors.
- Did my best to make a solid GND plane. In the lower right corner some parts of GND are on the top layer.
- Added a 100nF capacitor. Now both the LCD connector and the ADS1115 have a separate 100nF capacitor.
- Changed the netclass clearance from 0.13mm to 0.22mm and also fattened the tracks to 0.3mm and enlarged the via’s a bit.
I reduced the clearance in the Zone properties a bit, so the GND plane can sneak in between the the THT pins:
For hand soldering, i would rather use the “Longpads” versions. These are specifically made for hand soldering and also have more room between the pads for the GND to sneak through (Or did I make a few of those myself long ago? Can’t remember).
*Cleaned up Silk screen a bit. - Added some logo’s.
- Added revision string with the date on the PCB.
- Added TP1, A test point for GND. Always handy to have something to connect your scope to. I usually use two holes so a wire loop can be added. It can also be useful to put more label text near the connector pins, but the PCB is getting a bit crowded.
Front:
Backside with GND plane:
I made a copy of the PCB folder and deleted most unnecessary files. You can tell GIT to not keep track of backup copies of files.
There also is a 670KiB “Drok_Juntek_on_Steroids.kicad_pcb” which I deleted. The PCB itself is the 304KiB “JuntekOnSteroidsTTGO.kicad_pcb”.
Now it fits in a 75KiB Zip file. I’m not in the mood to go struggling with GIT, so here it is:
KICAD_Dron_Juntek_2021-08-27.zip (76.7 KB)
Oops (again)
I still have not looked at your Gerbers. I did not even generate them from this revision. I did notice there is a lot of silk screen outside of Edge.Cuts. Some manufacturers complain about this, and this can lead to delays in manufacturing. Ideally you should remove those graphics from the silkscreen.
