On the left is the v8 white grid origin point. On the right is the red version left over from v7. I’m sure the red one should not be there, so how can it be deleted? Further more, how can the white one also be deleted?
White is grid origin, red is Pick&Place origin. To remove them, you must put them at (0,0) coordinates.
Thanks fred4u. White now gone, but I can’t figure out how to deal with the red one.
EDIT: Found it. It’s in the Place menu.
For your information, if you hold-down left mouse button on the Grid origin toolbar item, you can select between setting Grid origin and Pick&Place origin.
