If someone is doing scripted panelization, I’ve recently had panels manufactured with v-cut as vertical separation of boards, and routed slots for horizontal separation, this worked well. Just for reference, the code draws the V-cut in the pcbnew module in the Eco1.User layer, plots the Gerber, and changes the output file to Vcut following the Gerber X2 file format. And as I said, this was handled without issue by the manufacturer. The relevant code is as follows:
##### Generate gerbers for Vcut
if Eco1_as_Vcut:
pctl.SetLayer(pcbnew.Eco1_User)
pctl.OpenPlotfile("Vcut", pcbnew.PLOT_FORMAT_GERBER, "Vcut")
pctl.PlotLayer()
pctl.ClosePlot()
# Change Eco1.User to Vcut inside Gerber X2 file, see
# https://www.ucamco.com/files/downloads/file/81/the_gerber_file_format_specification.pdf
with open(pctl.GetPlotFileName(), "r+") as f:
contents=f.readlines()
for i,line in enumerate(contents):
if line=="%TF.FileFunction,Other,ECO1*%\n":
contents[i]="%TF.FileFunction,Vcut*%\n"
f.seek(0)
f.truncate()
f.write("".join(contents))
