Hi, wanting panelize some PCBs to have made by jlcpcb and am using the kiKit plugging to do this, as was wondering if there was a recommended horizontal and vertical gap to compensate for the cutting process?
This is probably something you should ask jlcpcb. That said, I have a box of v scored boards in the basement somewhere. I’ll see if I can find it quickly. I moved recently, otherwise I’d just do a measurement.
It’s actually quite small, in the order of a mm for the cut. Also it’s more acute than they make it look in diagrams, more like 30° than 60°. If you look casually it may look like there’s no cut, just a line. But pay attention to their requirements to leave space around the cut.
Board was approximately where I expected. 1mm is a good figure. The rule in the photos is mm. Seems scored on each side.
Thank you so much for taking the time to do that!
Really appreciate it.
No problem. Actually, it’s probably the easiest thing I’ve done today.
My thought is zero offset. The V-cut doesn’t affect the size of board. It just chamfers the edge.
I 100% see where you coming from, but I’m thinking of sanding that chamfer flat for a more attractive board.
Some people add chamfers for looks. I bought some 8 led boards that I had to break apart. The chamfers are very very small and I needed a magnifying glass to see them. I spent days investigating them. I’m anxious to see how you do.
