Variant management in KiCad schematic
is there a possibility to manage assembly variants in schematic? Different part values or do not place marker?
Thank you for your help
BR
martin
“Do not populate” has native support, you can set it for each component in a schematic in the properties window.
for different part values you can use additional fields for a symbol and use tools like the iBOM to generate population files for different variants.
DNP flag: can be set in symbols properties.
extended variant management: not natively implemented, there is a older feature request pending on gitlab: Create a PCB assembly variant system (lp:#1767218) (#2131) · Issues · KiCad / KiCad Source Code / kicad · GitLab
Upvote that issue (or any other issue) if you find it useful. (upvoting == thumbs-up icon directly below the feature request, not a manual answer).
Until that is implemented you could try the following python-plugins which implement variant systems based on additional custom fields:
  • InteractiveHTML BOM
  • Kicost
  • KiBom
  • iBom
I have not tested these addons, so for more advice regarding these addons you have to wait for more answers.
