Why do I have to have the same value for multi-part symbols? For example if you have a multigang potentiometer with different value pots in the same part it would be nice to have the appropriate (and different) values in-front of the correct parts.
For the records, ‘parts are identical’ is unchecked in the symbol library.
EEschema framework is a couple years old by now… it’s being worked on to be better, but won’t make it for the v5 update I think.
A lot more should be possible once that’s here.
Just to add to this idea:
This text field is not editable outside the library editor. Neither the text itself nor the position of the text can be changed from within the schematic.
This means you need one symbol for each differing component. (probably for each order number)
That would be a proper use of the atomic part idea.
