V9 Schematic edit CTRL_D bug?
Bug or something odd with my graphics card?
In schematic editor:
  1. Copy some image to the clipboard (I used Windows snipping tool to grab a bit of screen)
  2. Click to select a component
  3. Press CTRL-D to duplicate
The original clipboard image is pasted, not the component
Application: KiCad Schematic Editor x64 on x64
Version: 9.0.0, release build
wxWidgets 3.2.6
FreeType 2.13.3
HarfBuzz 10.2.0
FontConfig 2.15.0
libcurl/8.11.1-DEV Schannel zlib/1.3.1
OpenGL: Intel, Intel(R) UHD Graphics 770, 4.6.0 - Build 32.0.101.6129
Date: Feb 19 2025 17:46:53
Boost: 1.86.0
OCC: 7.8.1
Curl: 8.11.1-DEV
ngspice: 44
KICAD_IPC_API=ON
Locale:
Lang: en_GB
Enc: UTF-8
Num: 1,234.5
Test with 9.0.1 and report this as a bug if the problem persists.
This was fixed shortly after v9.0 release: Duplicate operation leads to pasting of clipboard image instead of selected or hovered item (#19973) · Issues · KiCad / KiCad Source Code / kicad · GitLab
OK good. It’s not a biggie because I can just use CTRL-C CTRL-V instead.
Maybe time to go to 9.0.1 anyway. I take it the install picks up settings, paths etc?
Yes, it keeps all your stuff untouched, only files under Program Files are replaced.
