V9 netclass seems to always add "Default"
First thanks for releasing V9, it’s definitely a huge leap forward ! You’ve done an awesome job :slight_smile:
I’m exploring the rule zone feature since yesterday, but I’m facing an issue I can’t figure out. When drawing a rule zone, to assign a netclass “DGND”, nets inside the zone do correctly get “DGND” net assignation, but they do keep “Default” class as well.
My question is simple: how to remove “Default” netclass assignment to the nets inside my rule zone ?
Having Default assigned seems to be breaking my custom DRC rules that I’ve created under V8.0.
Is someone else facing the same issue ?
This is a new added behaviour. Nets can have multiple netclasses assigned.
I think you can’t remove the “default” netclass.
My naive question is which class has priority ?
If default has to stay, and I have let say a “high_voltage” class, that requires clearance of 2mm, while default is 0.2mm, how do I know which one is applied to the net ?
Since the update this kind of simple custom rules is no longer enforced by the DRC as it seems…
(rule VIHigh_DGND
   # Set clearance for IBus tracks to digital
   (constraint clearance (min 1mm))
   (condition "A.NetClass == 'IBUS' && B.NetClass == 'DGND'"))
It’s worth checking the documentation for net classes here which explains priority: PCB Editor | 9.0 | English | Documentation | KiCad
Also see the custom rule documentation for the Netclass property. Especially see hasNetclass().
So there are two parts to this… For the first part (Default netclass being present) - this will always be the case if you have some elements of the required netclass undefined. As there can be multiple netclasses assigned to a net, the resulting netclass takes a given field’s value from the highest priority netclass on which it is defined. These values are always defined on the Default netclass, so it’s being used to fill in the gaps. Note that the netclass settings table has some hidden columns, depending on whether you open it from the schematic or pcb editor. You can always right-click on the column headings to enable the others. This isn’t great UI, and we are thinking of ways to improve it.
For your second point, the condition "A.NetClass == 'IBUS' matches the full netclass name of object A (likewise for object B in your example). As you have the Default netclass included implicitly, the full name is actually IBUS,Default. Much better in v9 is to use the condition A.hasNetclass('IBUS'), as this will test all netclasses assigned to an object.
Thanks for the details, I understand better now :slight_smile:
Thanks for pointing me out the hasNetclass function, I’ll update my custom rules with it.
Last question from my side on this new netclass system :
Is there a smart way to sort out all nets that are “only” default ?
In V8 I used to check that I correctly assigned all my nets so that they are not “Default” anymore.
And for that I used the hide/show option in the side panel in “nets” tab. But this method no longer works with the new netclass system.
It works for me to show and hide ratsnest lines. In v8 did it show / hide tracks? I’m not quite sure what your use-case is (a video / images of your v8 workflow would be useful to know if this is a regression).
Hi there,
i stumbled upon this today. So I have one netclass “USB” defined, trace width and spacing is 0.125mm.
I assigned it to all D+ and D- nets. From the documentation we/I learned that the “default” netclass always has lowest prioirity.
So why is the default netclass still there and why does it use the 0.2mm from default as clearance and the 0.125 from USB as trace width, although “usb” has a higher priority? I assigned the 0.125mm also to the DP spacing/trace width.
The Default netclass bit is explained in the post above (and in the docs): V9 netclass seems to always add "Default" - #5 by JamesJ
As you don’t have uVia defined on the net class, it also gets the Default netclass assigned in order to get those values.
On the clearance bit - what is the board clearance set to? Can you share the project so I can take a look?
What do you mean by “board clearance”?
The minimum clearance in board constraints is set to “0”.
Here’s the project
USBHubPlus_4JamesJ.zip (1.0 MB)
@Knochi : unrelated to your netclass issue: the example project shows a strange behaviour and provokes crashes on my kicad installation. May I use it as example for a bug report?
Sure, no problem.
Anything you can tell why it is crashing?
No idea. I have not seen such a behaviour on my own projects before.
open gitlab issue: kicad closes (crash?) at closing schematic with example project (#20778) · Issues · KiCad / KiCad Source Code / kicad · GitLab
@JamesJ : regarding the netclass-clearance issue I think it could be a bug. But I’m not 100% sure in this area, so it would be good if you could look into the example project.
Yep I’ll take a look!
So this is a bug. I’ll work on a fix…
It looks like composite netclasses that are constructed from pattern matching assignments don’t get an implicit DRC rule created. So, the DRC engine doesn’t find a matching DRC clearance rule for the composide netclass USB,Default, so the engine falls back to the Default netclass value.
Ok so I tried to define the netclass by directive labels in the schematic and delete the assignment in PCB netclasses, result is the same.
It gets even more weird, when i do both.
Then the tracks get “USB,USB and Default”
I’ve fixed the duplicated net class issue. Will continue to investigate the clearance problem.
Now fixed. Will be in 9.0.2. Thanks for finding this!
It was critical to me as well, having the “Default” netclass included when you initiate a new netclass from the schematic, then you use it in the schematic, but since from the Schematic Setup you get no full access to all the fields of the newly created netclass, you always find the Default class included.
I solve going into the PCB and filling all the fields.
I suggest, when creating a new netclass, to copy all the fields from the Default class, instead of having it together with the new one, which is very annoying.
Francesco
You can right-click on the column headers and enable all the PCB columns in the schematic setup page (and vice-versa). The schematic / PCB setup pages just default to only showing the schematic or PCB fields.
