V9 MacOS Sequoia - Problems printing
I just upgraded from v8 to v9. In v8 I was able to print to Letter size and the page would be filled as appropriately by the print routine. In v9 the print is half the page. In both instances I used landscape.
Interestingly when I print to PDF and open to Preview the page looks correct however when printed it is half of the page as well.
I have double checked page settings and it is correct.
Other apps print fine in landscape and the MacOS is the same for both v8 and v9.
Any ideas how to make v9 print correctly?
In case anyone runs across this it is solved. The HP printer was set to auto update which it did. That updated required new printer software on the MAC. No information was displayed or flagged on the MAC. So I did something on my MAC I used to have to do all the time with windows. Install new driver and software.
After installing new software I then deleted the original printer in System Settings - Printers Scanners. Then created a new printer and I set it to default.
Bingo. All is good again.
