Hi. My project have been created with V8, I’m currently in 8.01 release.
First version of the project went to fab without any issue. I just finished V2 of the layout and need to resize the pcb. I go to the Edge.cuts view and have no way to modify the edge : no square anchor appears in the corners… PCB stat reports the right size (100*100). I’m stuck here !
I tried to create a new perimeter, it works ok : I can draw a new one with visible and functional anchor. But PCB stat report a pcb size which is a mix of the two. Clearly the initial perimeter is active but not modifiable…
Please not that I cannot select it : the two lock / unlocks is the icon bar are always grayed.
Attached pic shows Edge.cuts view with perimeter impossible to select.
Any help appreciated, I have to find a way to use my new layout !
Thanks
