I’ve been using v7 for the past few days and I’ve run into a rather annoying issue with Drawing Sheet Editor.
It will periodically crash as I am editing the drawing sheet. This normally happens after adding a new item to the sheet or moving existing items. With the item still selected, the program will freeze for several seconds and then close. There are no error messages.
It’s not consistent either. I can place several items in a row before a crash occurs.
Has anyone else run into this issue. Any known fixes out there?
SW Version Info:
Application: KiCad Drawing Sheet Editor x64 on x64
Version: 7.0.2, release build
wxWidgets 3.2.2
FreeType 2.12.1
HarfBuzz 6.0.0
FontConfig 2.14.1
libcurl/7.88.1-DEV Schannel zlib/1.2.13
Date: Apr 15 2023 19:18:27
wxWidgets: 3.2.2 (wchar_t,wx containers)
Boost: 1.81.0
OCC: 7.6.3
Curl: 7.88.1-DEV
ngspice: 40
Compiler: Visual C++ 1934 without C++ ABI
KICAD_SPICE=ON
