Hi!
I’m currently switching from v5.1.12 to v6.0.0 and encountered following problem.
To mark the different layers for the manufacturer, I’m writing the layer numer to the copper (Top=1, In2=2, In3=3, Bottom=4).
In 5.1.12 this was no big issue, the copper clearance around the numer is approx. 0.3mm.
The zone and track clearance is set to 0.15mm
Now in v6.0.0 the clearance around the numbers is approx. 0.7mm, which is way to much for my current layout.
The clearance settings in both files are the same.
Is there another setting to reduce the clearance around text on copper in v6.0.0?
The clearance comes from normal clearances: board setup constraints, net clearance, zone clearance. But there’s some extra space around text, maybe it’s some fixed value and I don’t see a way to adjust it. IMO this should be adjustable in some way and you could file an issue for it.
It does give the expected result from the known clearance values, but still the text has extra clearance which can’t be controlled and which isn’t visible as a number anywhere.
One thing I forgot to mention:it will still be larger than the spacing around text in 5.0 (because 5.0 failed to account for descenders and diacriticals correctly). But it won’t be as large as it was in 6.0.0 and 6.0.1. (The fix went in to 6.0.2, which should be released sometime in Feb.)
