V6.99 Nightly - Crash when deleting unused net in Board editor -> Net inspector
Has someone gotten a crash when attempting to remove an unused net in the net inspector of the board editor by using the trashcan button in the dialog box?
If I click trashcan on net 1, 2, 4 or 5 in the screenshot below I get a popup with a question whether I really want to delete the net even if it is in use, but if I want to delete the net 3 GND it highlights net 4 and then in a second or two KiCad crashes completely, all windows including project manager.
Upon restarting KiCad it doesn’t even remember which project I worked on last, and when I open the project again in Board Editor, the last change I did before trying to remove the net, which was changing the net of the mounting hole PEGND1 on the right from GND to Earth protective (#5) is undone.
I’m not sure if this is specific to my project because there is something wrong with it, but I wouldn’t like KiCad to crash just like that anyway…
Version: 6.99.0-1.20230103gitbaa13b8.fc37, release build
wxWidgets 3.2.1
FreeType 2.12.1
HarfBuzz 5.2.0
FontConfig 2.14.1
libcurl/7.85.0 OpenSSL/3.0.5 zlib/1.2.12 brotli/1.0.9 libidn2/2.3.4 libpsl/0.21.1 (+libidn2/2.3.3) libssh/0.10.4/openssl/zlib nghttp2/1.51.0
Platform: , 64 bit, Little endian, wxGTK, KDE, wayland
Date: Jan 3 2023 18:17:25
Boost: 1.78.0
OCC: 7.5.0
Curl: 7.85.0
ngspice: 38
Compiler: GCC 12.2.1 with C++ ABI 1017
KICAD_SPICE=ON
I can reproduce this with:
  1. Extract the project into a new directory.
  2. Delete all the _autosave* files. (or else KiCad attempts some recovery).
  3. Open the Project.
  4. Open PCB Editor.
  5. Klick OK to: “The wxPython library was compiled against wxWidgets 3.0.4 but KiCad is using 3.2.1 Python plugins will not be available”.
  6. PCB Editor / Inspect / Net Inspector.
  7. Select any of the nets!
  8. Click on the garbage bin icon.
  9. KiCad crashes with: “Segmentation fault (core dumped)”
paul@cezanne:~$ kicad-nightly
After that I opened one of my own projects and KiCad also crashes when deleting a net.
So I consider this confirmed and worthy of a bug report on Gitlab.
Also, for the next time:
Make your screen shots smaller. Never make them of maximized windows. I have a pretty big monitor with the same resolution as yours, but on a web page the browser still has to fit around it. It’s rarely useful to make screenshots wider than around 1200 pixels.
Version: 6.99.0-unknown-7d1f25fbf1~164~ubuntu20.04.1, release build
	wxWidgets 3.2.1
	FreeType 2.10.1
	HarfBuzz 2.6.4
	FontConfig 2.13.1
Platform: Linux Mint 20.3, 64 bit, Little endian, wxGTK, xfce, x11
	Date: Jan  3 2023 21:39:21
	Boost: 1.71.0
	OCC: 7.5.2
	Curl: 7.68.0
	ngspice: 38
	KICAD_USE_EGL=ON
	KICAD_SPICE=ON
If I click yes on the question in the popup for net 1,2,4 and 5, it crashes too.
On 3 it crashes immediately because that net is not in use so it doesn’t ask.
I just didn’t try the other ones before, so I didn’t notice.
It doesn’t have to be my zipped project above either, I get the same if I open a random one (ecc83 v2) of the demo projects in /usr/share/kicad/demos and try to put any random net in the garbage can.
Gitlab issue #13377. Commit 20d7ffd5 by Seth Hillbrand about 13 minutes after the issue was entered in gitlab… Should be testable in tomorrows nightly build.
Deleting nets works again in tonights nightly build for f37, so the fix seems to have removed the crash.
Version: 6.99.0-1.20230105git1d9783ed.fc37, release build
Libraries: wxWidgets 3.2.1 FreeType 2.12.1 HarfBuzz 5.2.0 FontConfig 2.14.1 libcurl/7.85.0 OpenSSL/3.0.5 zlib/1.2.12 brotli/1.0.9 libidn2/2.3.4 libpsl/0.21.1 (+libidn2/2.3.3) libssh/0.10.4/openssl/zlib nghttp2/1.51.0
Build Info: Date: Jan 5 2023 18:15:19 wxWidgets: 3.2.1 (wchar_t,wx containers) GTK+ 3.24 Boost: 1.78.0 OCC: 7.5.0 Curl: 7.85.0 ngspice: 38 Compiler: GCC 12.2.1 with C++ ABI 1017
Build settings: KICAD_SPICE=ON
Same for me.
I can now also delete a net with the Net Inspector without KiCad crashing.
