V5.1 - via drill less than minimum via drill?
I want to change via size and drill in File > Board Setup (0.4 mm size, 0.2 mm drill), but it says “Via drill less than minimum via drill (0.3 mm)”. Where do I change that? Changing values in DRC does no use.
They’re both in File > Board Setup.
The basic value is in File > Board Setup > Constraints.
Thank you so much! Btw is “via drill” the hole diameter and “via diameter” the annular ring diameter?
Yes. And some 20 characters
