Hi Guys,
Today I installed v5.1.2 unfortunatly, not all went as smoothly as I would have liked to.
After the installation completed, I created a .BAT file to launch KiCAD v5.1.2 and run it along my previous two versions (v4.7 and v5.0.2)
.bat file
SET KICAD_CONFIG_HOME=C:\Users\Uniterra\AppData\Roaming\KiCad_5_1_2
START /d “C:\Program Files\KiCad_5\bin” kicad.exe
The first thing I did is to try to open an existing project created with v5.0.2, the symbol table had to be created, I choose the recommended option
The rescue library was also missing
I do not have OpenGL support in this computer, but have been always able to work in fallback mode, I got this dialog twice on top of each other
As I chose no to rescue symbols (I was planning to edit my symbol table later on).
I got the following dialog, when the Schematic finally displayed (the very first time the schematic didn’t got displayed, on trying to reproduce the bug, it got displayed for some seconds)
I finally got the following dialog, I had to terminate KiCAD
EDIT1: Trying to open PCB instead of the schematic first show the following dialog
If I politely choose “No thank you” when offered OpenGL support, the application hangs
If a choose accelerated mode, I get a dialog telling me that is not possible and that fallback mode will be used, then the PCB works as expected.
Trying to open the the schematic editor shows me an empty window, that doesnt crash … until I try to switch to fallback mode
EDIT2: I filed a bug report
https://bugs.launchpad.net/kicad/+bug/1828071
My system information is as follows
Application: kicad
Version: (5.1.2)-1, release build
wxWidgets 3.0.4
libcurl/7.61.1 OpenSSL/1.1.1 (WinSSL) zlib/1.2.11 brotli/1.0.6 libidn2/2.0.5 libpsl/0.20.2 (+libidn2/2.0.5) nghttp2/1.34.0
Boost: 1.68.0
Curl: 7.61.1
Compiler: GCC 8.2.0 with C++ ABI 1013
USE_WX_GRAPHICS_CONTEXT=OFF
USE_WX_OVERLAY=OFF
KICAD_SCRIPTING=ON
KICAD_SCRIPTING_MODULES=ON
KICAD_SCRIPTING_PYTHON3=OFF
KICAD_SCRIPTING_WXPYTHON=ON
BUILD_GITHUB_PLUGIN=ON
KICAD_USE_OCE=ON
KICAD_USE_OCC=OFF
KICAD_SPICE=ON
