I just updated to Kicad 5 and had to update a symbol in one of my project libraries and after that the symbol in the schematic editor looks very different from the library editor(see attached picture)
Hmm, did some more testing and while it may be true that the “Automatically place symbol fields” options has always been on by default it cannot explain the different behaviour that I’m seeing between library items saved with 4.0.7 and 5.0
The test I conducted was the following.
I have a library created with 4.0.7 initially that contains 2 symbols. One symbol remains untouched but the other is updated using the new lib editor in 5.0 and saved.
When I place the symbol created in 4.0.7, with “Automatically place symbol fields” ON it respects the value and reference field locations. When rotating the symbol the relative positioning is kept(i.e. they do not get translated to arbitrary locations within the symbol) and text gets mirrored correctly
When I place the symbol created in 4.0.7, with “Automatically place symbol fields” OFF the same behaviour is observed as in the previous test.
When I place the symbol created in 4.0.7 and updated in 5.0 with “Automatically place symbol fields” ON it does not respect the relative positioning of the value and reference fields(See picture in the original post). When rotating, the fields get moved and mirrored based on this new “relative positioning” so the fields are legible.
When I place the symbol created in 4.0.7 and updated in 5.0 with “Automatically place symbol fields” OFF I observe the same behaviour as with the symbol not touched by 5.0, described in the first two tests above.
Something weird is definitely going on.
Noticed this became a lot longer than intended, maybe it would help to create a small screen capture demonstrating the problem?
Yes, and perhaps you say highlight which behaviour is unexpected. You make a series of observations and then say it’s weird, but we don’t know what you are expecting to see.
