Today I booted into Debian Buster (Dual boot, Other is Mint 17 with KiCad 4.0.7 on another partition, but with the same /home) and did apt - update / upgrade / dist-upgrade and then started KiCad 5 for the first time.
I also seem to have problems with OpenGL.
Version info:
Application: kicad
Version: 5.0.0-rc3+dfsg1-1, release build
wxWidgets 3.0.4
libcurl/7.60.0 OpenSSL/1.1.0h zlib/1.2.11 libidn2/2.0.4 libpsl/0.20.2 (+libidn2/2.0.4) libssh2/1.8.0 nghttp2/1.32.0 librtmp/2.3
Platform: Linux 4.16.0-2-amd64 x86_64, 64 bit, Little endian, wxGTK
wxWidgets: 3.0.4 (wchar_t,wx containers,compatible with 2.8) GTK+ 2.24
Boost: 1.62.0
Curl: 7.60.0
Compiler: GCC 7.3.0 with C++ ABI 1011
USE_WX_GRAPHICS_CONTEXT=OFF
USE_WX_OVERLAY=OFF
KICAD_SCRIPTING=ON
KICAD_SCRIPTING_MODULES=ON
KICAD_SCRIPTING_WXPYTHON=OFF
BUILD_GITHUB_PLUGIN=ON
KICAD_USE_OCE=ON
KICAD_USE_OCC=OFF
KICAD_SPICE=OFF
I can run KiCad / EEschem / PCBnew, but I can not activate the OpenGL canvas in PCBnew.
[F11] says:
Warning
OpenGL 2.1 or higher is required!
But apart from that PCBnew seems to work with the legacy canvas.
However, when I attempt to start the 3D viewer I get a few errors, with an option to show a “Backtrace:” with more info:
ASSERT INFO:
…/src/gtk/window.cpp(2996): assert “(m_widget != __null)” failed in DoGetClientSize(): invalid window
BACKTRACE:
[1] wxWindow::DoGetClientSize(int*, int*) const
[2] wxAuiManager::AddPane(wxWindow*, wxAuiPaneInfo const&)
[3] wxEvtHandler::ProcessEventIfMatchesId(wxEventTableEntryBase const&, wxEvtHandler*, wxEvent&)
[4] wxEventHashTable::HandleEvent(wxEvent&, wxEvtHandler*)
[5] wxEvtHandler::TryHereOnly(wxEvent&)
[6] wxEvtHandler::DoTryChain(wxEvent&)
[7] wxEvtHandler::ProcessEvent(wxEvent&)
[8] wxWindowBase::TryAfter(wxEvent&)
[9] wxEvtHandler::SafelyProcessEvent(wxEvent&)
[10] wxMenuBase::SendEvent(int, int)
[11] g_closure_invoke
[12] g_signal_emit_valist
[13] g_signal_emit
[14] gtk_widget_activate
[15] gtk_menu_shell_activate_item
[16] g_closure_invoke
[17] g_signal_emit_valist
[18] g_signal_emit
[19] gtk_propagate_event
[20] gtk_main_do_event
[21] g_main_context_dispatch
[22] g_main_loop_run
[23] gtk_main
[24] wxGUIEventLoop::DoRun()
[25] wxEventLoopBase::Run()
[26] wxAppConsoleBase::MainLoop()
[27] wxEntry(int&, wchar_t**)
[28] __libc_start_main
[29] _start
Pressing “Continue” pops up the next failed assertion:
ASSERT INFO:
…/src/gtk/window.cpp(2857): assert “m_widget” failed in DoSetSize(): invalid window
BACKTRACE:
[1] wxWindow::DoSetSize(int, int, int, int, int)
[2] wxBoxSizer::RecalcSizes()
[3] wxSizer::Layout()
[4] wxSizerItem::SetDimension(wxPoint const&, wxSize const&)
[5] wxBoxSizer::RecalcSizes()
[6] wxSizer::Layout()
[7] wxSizerItem::SetDimension(wxPoint const&, wxSize const&)
[8] wxBoxSizer::RecalcSizes()
[9] wxSizer::Layout()
[10] wxSizerItem::SetDimension(wxPoint const&, wxSize const&)
[11] wxBoxSizer::RecalcSizes()
[12] wxSizer::Layout()
[13] wxSizerItem::SetDimension(wxPoint const&, wxSize const&)
[14] wxBoxSizer::RecalcSizes()
[15] wxSizer::Layout()
[16] wxSizerItem::SetDimension(wxPoint const&, wxSize const&)
[17] wxBoxSizer::RecalcSizes()
[18] wxSizer::Layout()
[19] wxSizerItem::SetDimension(wxPoint const&, wxSize const&)
[20] wxBoxSizer::RecalcSizes()
[21] wxSizer::Layout()
[22] wxSizerItem::SetDimension(wxPoint const&, wxSize const&)
[23] wxBoxSizer::RecalcSizes()
[24] wxSizer::Layout()
[25] wxWindowBase::Layout()
[26] wxAuiManager::DoFrameLayout()
[27] wxAuiManager::Update()
[28] wxEvtHandler::ProcessEventIfMatchesId(wxEventTableEntryBase const&, wxEvtHandler*, wxEvent&)
[29] wxEventHashTable::HandleEvent(wxEvent&, wxEvtHandler*)
[30] wxEvtHandler::TryHereOnly(wxEvent&)
[31] wxEvtHandler::DoTryChain(wxEvent&)
[32] wxEvtHandler::ProcessEvent(wxEvent&)
[33] wxWindowBase::TryAfter(wxEvent&)
[34] wxEvtHandler::SafelyProcessEvent(wxEvent&)
[35] wxMenuBase::SendEvent(int, int)
[36] g_closure_invoke
[37] g_signal_emit_valist
[38] g_signal_emit
[39] g_closure_invoke
[40] g_signal_emit_valist
[41] g_signal_emit
[42] gtk_accel_group_activate
[43] gtk_accel_groups_activate
[44] gtk_window_activate_key
[45] g_closure_invoke
[46] g_signal_emit_valist
[47] g_signal_emit
[48] gtk_propagate_event
[49] gtk_main_do_event
[50] g_main_context_dispatch
[51] g_main_loop_run
[52] gtk_main
[53] wxGUIEventLoop::DoRun()
[54] wxEventLoopBase::Run()
[55] wxAppConsoleBase::MainLoop()
[56] wxEntry(int&, wchar_t**)
[57] __libc_start_main
[58] _start
“Continue” again & 3rd error:
ASSERT INFO:
…/src/gtk/window.cpp(3578): assert “m_widget != __null” failed in SetFocus(): invalid window
BACKTRACE:
[1] wxWindow::SetFocus()
[2] wxEvtHandler::ProcessEventIfMatchesId(wxEventTableEntryBase const&, wxEvtHandler*, wxEvent&)
[3] wxEventHashTable::HandleEvent(wxEvent&, wxEvtHandler*)
[4] wxEvtHandler::TryHereOnly(wxEvent&)
[5] wxEvtHandler::DoTryChain(wxEvent&)
[6] wxEvtHandler::ProcessEvent(wxEvent&)
[7] wxWindowBase::TryAfter(wxEvent&)
[8] wxEvtHandler::SafelyProcessEvent(wxEvent&)
[9] wxMenuBase::SendEvent(int, int)
[10] g_closure_invoke
[11] g_signal_emit_valist
[12] g_signal_emit
[13] g_closure_invoke
[14] g_signal_emit_valist
[15] g_signal_emit
[16] gtk_accel_group_activate
[17] gtk_accel_groups_activate
[18] gtk_window_activate_key
[19] g_closure_invoke
[20] g_signal_emit_valist
[21] g_signal_emit
[22] gtk_propagate_event
[23] gtk_main_do_event
[24] g_main_context_dispatch
[25] g_main_loop_run
[26] gtk_main
[27] wxGUIEventLoop::DoRun()
[28] wxEventLoopBase::Run()
[29] wxAppConsoleBase::MainLoop()
[30] wxEntry(int&, wchar_t**)
[31] __libc_start_main
[32] _start
“Continue” again and 4th error:
ASSERT INFO:
BACKTRACE:
[27] wxAuiManager::OnSize(wxSizeEvent&)
[31] wxEvtHandler::ProcessEventLocally(wxEvent&)
[33] wxEvtHandler::SafelyProcessEvent(wxEvent&)
[34] g_closure_invoke
[35] g_signal_emit_valist
[36] g_signal_emit
[37] gtk_widget_size_allocate
[38] g_closure_invoke
[39] g_signal_emit_valist
[40] g_signal_emit
[41] gtk_widget_size_allocate
[42] g_closure_invoke
[43] g_signal_emit_valist
[44] g_signal_emit
[45] gtk_widget_size_allocate
[46] g_closure_invoke
[47] g_signal_emit_valist
[48] g_signal_emit
[49] gtk_widget_show
[50] wxEvtHandler::ProcessEventIfMatchesId(wxEventTableEntryBase const&, wxEvtHandler*, wxEvent&)
[51] wxEventHashTable::HandleEvent(wxEvent&, wxEvtHandler*)
[52] wxEvtHandler::TryHereOnly(wxEvent&)
[53] wxEvtHandler::DoTryChain(wxEvent&)
[54] wxEvtHandler::ProcessEvent(wxEvent&)
[55] wxWindowBase::TryAfter(wxEvent&)
[56] wxEvtHandler::SafelyProcessEvent(wxEvent&)
[57] wxMenuBase::SendEvent(int, int)
[58] g_closure_invoke
[59] g_signal_emit_valist
[60] g_signal_emit
[61] g_closure_invoke
[62] g_signal_emit_valist
[63] g_signal_emit
[64] gtk_accel_group_activate
[65] gtk_accel_groups_activate
[66] gtk_window_activate_key
[67] g_closure_invoke
[68] g_signal_emit_valist
[69] g_signal_emit
[70] gtk_propagate_event
[71] gtk_main_do_event
[72] g_main_context_dispatch
[73] g_main_loop_run
[74] gtk_main
[75] wxGUIEventLoop::DoRun()
[76] wxEventLoopBase::Run()
[77] wxAppConsoleBase::MainLoop()
[78] wxEntry(int&, wchar_t**)
[79] __libc_start_main
[80] _start
“Continue” again and then KiCad crashes completely. I had started KiCad from the commandline, and in the meantime the terminal window has also spit out a summary of the above errors:
paul@dualcore:~$ kicad
21:05:10: Debug: Checking template path ‘/usr/share/kicad/template’ exists
21:05:10: Debug: FileWatcherReset: add ‘/home/paul/projects/kicad/mumar-basisprint-st32f103c8t6/lib.pretty’
21:05:10: Debug: FileWatcherReset: add ‘/home/paul/projects/kicad/mumar-basisprint-st32f103c8t6/rescue-backup’
21:05:13: Debug: Loading project ‘/home/paul/projects/kicad/mumar-basisprint-st32f103c8t6/mumar-basisprint-st32f103c8t6.pro’ settings.
libGL error: No matching fbConfigs or visuals found
libGL error: failed to load driver: swrast
Trace/breakpoint trap
My Video card is a GeForce 210 (N218)
paul@dualcore:~$ glxinfo |grep “OpenGL version”
OpenGL version string: 3.3.0 NVIDIA 340.107
paul@dualcore:~$ glxinfo > glxinfo.txt
glxinfo.txt.tar.gz (5.7 KB)
This Video driver could be a bit old, but it is what debian Buster installs by default.
I did see something about a “legacy driver” but I can’t remember where.
I tried to collect what info I can, but I do not understand much of this stuff…
Maybe I should also put this in a bug report somewhere, but I would like some feedback on this before I try to attract some developer’s attention.
