I’ve been out of the loop, know that others will be able to address this much faster than me trying to stumble along trying to figure out if it has already been reported.
In Eeschema, the “?” hot-key toggles the add a buss entry command. It can not be fixed by resetting it.
In PcbNew, the “?” is not set by default to bring up the hot-key menu; it was cntrl+F1 (I think).
Application: kicad
Version: (5.0.0-rc2-dev-493-gd776eaca8), release build
wxWidgets 3.0.3
libcurl/7.54.1 OpenSSL/1.0.2l zlib/1.2.11 libssh2/1.8.0 nghttp2/1.23.1 librtmp/2.3
wxWidgets: 3.0.3 (wchar_t,wx containers,compatible with 2.8)
Boost: 1.60.0
Curl: 7.54.1
Compiler: GCC 7.1.0 with C++ ABI 1011
USE_WX_GRAPHICS_CONTEXT=OFF
USE_WX_OVERLAY=OFF
KICAD_SCRIPTING=ON
KICAD_SCRIPTING_MODULES=ON
KICAD_SCRIPTING_WXPYTHON=ON
BUILD_GITHUB_PLUGIN=ON
KICAD_USE_OCE=ON
KICAD_SPICE=ON
