ravn
October 2, 2023, 6:46am
1
I am trying so set up design rules for a microwave board and needs to set strict rules on microvias between different layers. Thus, I did the rule:
(rule "L1 -> L3 uvia"
(constraint hole_size (min 0.175mm) (max 0.175mm))
(condition "A.Type == 'Via' && A.Via_Type == 'Micro' && A.fromTo('L1.Cu','L2.Cu')")
The problem is that when I have the A.fromTo() in the condition, it does not trigger on this micro via:
Have I misunderstood the fromTo?
Thanks,
Robert
ravn
October 2, 2023, 9:55am
2
A solution is to use something like:
(condition "A.Type == 'Via' && A.Via_Type == 'Micro' && A.existsOnLayer('L1.Cu') && A.existsOnLayer('L2.Cu') && !A.existsOnLayer('L3.Cu') && !A.existsOnLayer('L4.Cu') && !A.existsOnLayer('L5.Cu') && !A.existsOnLayer('L6.Cu')")
Does not explain the use of the fromTo-function, but is awork-around.
From | | | Documentation | KiCad under Custom rule syntax in table Expression functions at fromTo('x', 'y')
Returns true if the object exists on the copper path between the given pads. x and y are the full names of pads in the design, such as ‘R1-Pad1’.
Looks like fromTo() checks for the connected pads rather than the layers.
Maybe you could try Layer_Bottom and Layer_Top ? Maybe something like
(version 1)
( condition
"A.Type == 'Via' && A.Via_Type == 'Micro' && A.Layer_Top == 'L1.Cu' && A.Layer_Bottom == 'L2.Cu' "
? (assuming you named the layers L1.Cu and L2.Cu, which isn’t the default of In1.Cu and In2.Cu)
(Edit: Corrected example)
ravn
October 2, 2023, 10:32am
4
Thanks. That sounds like the right thing. Tried it, but does not work. This looks like a bug actually. From the constraints report:
Checking rule L1 -> L3 uvia hole size: min 0,1750 mm; opt undefined; max 0,1750 mm.
Checking rule condition "A.Type == 'Via' && A.Via_Type == 'Micro' && A.Layer_Top == 'L1.Cu' && A.Layer_Bottom == 'L2.Cu'".
Condition not satisfied; rule ignored
What version do you use? I use a older 7.99 Version, i get »No errors found.«
Which layer is L1.Cu and L2.Cu? Is L1.Cu above L2.Cu? If not, you may have to swap Layer_Top and Layer_Bottom in the rule?
Maybe you should check if you should open a GitLab issue report.
ravn
October 2, 2023, 11:41am
6
I use 7.0.8 and the idea is that I want to generate an error. I have a via that is work. I am kind of building a test-board at the moment with all rules and I have a via that is violating this rule, but it is not caught with the Layer_Top… solution. It is however captured with the existsOnLayer… construction.
I was talking about the rule checker errors, not about the DRC violations in the PCB.
No error in the Custom Rules Editor:
The Vias that violate that rule are reported:
twl
October 2, 2023, 8:15pm
8
fromTo can be used to define topology of a connection (eg. fromTo('IC1','IC2') would take all paths between pins of IC1 and IC2 into consideration. It was meant to define length constraints. There is no dedicated constraint/expression for blind/buried vias layer ranges yet - for the moment I suggest using the workaround proposed in this thread. Full pad/via stack definition will be coming to KiCad at some point in time.
Tom
ravn
October 3, 2023, 2:09pm
9
This is strange. Actually my 7.0.8 KiCA on Windows does not catch that when using the Layer_Top… construction?
(Errors are from other tests that should fail.)
Can you upload a project with that problem (including all files necessary to open it)?
ravn
October 3, 2023, 3:25pm
11
I have the same problem with your project. Maybe you should now open a GitLab issue (in case it is not already done).
It’s failing to take custom-layer names into account for Layer_Top and Layer_Bottom. It should work if you use the canonical layer names (“F.Cu” and “In1.Cu”).
system
Closed
January 4, 2024, 8:53pm
14
