In the past I successfully built 5.99. I am still using MacOS 10.14.6 Mojave which is not supported by the official build or nightlies, but which is it the last MacOS that allows to run 32-bit software.
I’d like to build the equivalent of the newest release, but unfortunately I cannot check out 6.0 as it is not available:
$ git branch -r
origin/4.0
origin/5.0
origin/5.1
origin/HEAD -> origin/master
origin/master
origin/weblate
Can this be made available, or is it on a different repository?
Hi @federerb ,
git fetch git@gitlab.com:kicad/code/kicad.git 6.0
git checkout -b 6.0 FETCH_HEAD
Above commands will checkout a new branch from upstream repo 6.0 branch to your local.
If you want to keep your local updated you should run:
git pull --rebase git@gitlab.com:kicad/code/kicad.git 6.0
to fast forward merge new commits from the official repo.
Thank you for replying.
Unfortunately I get “git@gitlab.com : Permission denied (publickey,keyboard-interactive).” in both cases.
Can you give it a try with the https url instead of ssh?
git fetch https://gitlab.com/kicad/code/kicad.git 6.0
Great, that worked. Thank you very much, @Aris_Kimi
Your welcome!! Happy building
system
Closed
July 6, 2022, 1:52pm
7
